dpeng's avatar
dpeng
9 months ago
Cyclone V: how to enable USB1 with a ULPI USB PHY (USB3320)?
I want to enable USB1 (USB 2.0 controller) of the Cyclone V in host-only mode. But Vbus is not present and no device is detected.
  • A ULPI-compatible Microchip USB3320 USB PHY is connected to the Cyclone V with a ULPI interface. The CPEN pin of the USB3320 controls a power switch on the board. To enable the 5V Vbus voltage, used to power USB devices, the CPEN pin must be driven high. Its POR state is low.
  • HPS_GPIO0 is connected to the active-low RESET# pin of the USB3320.
  • To check if Vbus is on, I connected a mouse, that should light up when connected to a USB host.
The main DT file is socfpga.dtsi. I altered it a little in both Barebox and Linux v6.6.22:
&usbphy0 {
	reset-gpios = <&porta 0 GPIO_ACTIVE_LOW>;
	status = "okay";
&usb1 {
	status = "okay";
	dr_mode = "host";
Barebox shows that GPIO0 (RESET#) is an output and is high, which is OK:
barebox:/ gpioinfo ff708000.gpio@ff708000:[email protected]
GPIOs 454-482, chip ff708000.gpio@ff708000:[email protected]:
             dir val requested name                 label
  GPIO    0: out hi  active low                      soc:usbphy.of reset
  GPIO    1: in  lo  false
  GPIO    2: in  lo  false
Barebox shows that the dwc2 driver binds to usb1:
barebox@Enclustra Mercury+ SA2:/ drvinfo dwc2
Driver  Device(s)
dwc2
        [email protected]
Linux boot log:
# dmesg | grep -Ei 'usb|dwc2'
[    0.042372] usbcore: registered new interface driver usbfs
[    0.042408] usbcore: registered new interface driver hub
[    0.042448] usbcore: registered new device driver usb
[    0.896138] usbcore: registered new interface driver usb-storage
[    0.920377] usbcore: registered new interface driver usbhid
[    0.932106] usbhid: USB HID core driver
[    1.086689] usb_phy_generic soc:usbphy: dummy supplies not allowed for exclusive requests
[    1.095129] dwc2 ffb40000.usb: supply vusb_d not found, using dummy regulator
[    1.111913] dwc2 ffb40000.usb: supply vusb_a not found, using dummy regulator
[    1.137639] dwc2 ffb40000.usb: DWC OTG Controller
[    1.142362] dwc2 ffb40000.usb: new USB bus registered, assigned bus number 1
[    1.149465] dwc2 ffb40000.usb: irq 48, io mem 0xffb40000
[    1.155604] hub 1-0:1.0: USB hub found
I was told that the "dummy regulator" messages are nothing to worry about.
More Linux commands:
# lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux 6.6.22 dwc2_hsotg DWC OTG Controller
# gpioinfo gpiochip0
gpiochip0 - 29 lines:
        line   0:      unnamed      "reset"  output   active-low [used]
        line   1:      unnamed       unused   input  active-high
        line   2:      unnamed       unused   input  active-high
Pastebin
  • Hi Alan,
    Thanks for giving it a thought. I finally got it working: a misconfigured switch. No comments, please...
    David
  • dpeng's avatar
    dpeng
    Hi Alan,
    David
  • David - I hate it when something like that happens!  Thanks for letting us know you figured it out!
    Sue
  • AlanCLTan's avatar
    AlanCLTan
    Hi dpeng,
    Let me understand further on your setup:
    1. CPEN routed to a VBUS power switch enable (active‑high)
    2. RESET# of the USB3320 driven by HPS_GPIO0 (active‑low)
    Is that correct?
    Could you confirm the checklist below:
    1. Confirm the 5 V input to the VBUS power switch is present.
    2. Verify the switch enable pin is active-high and connected to CPEN directly.
    3. Verify the reference clock to USP3320 (26MHz) is present and stable.
    4. Scope the ULPI CLK pin from the PHY (usually 60 MHz output to the MAC).
    5. Also check that ULPI I/O voltage rails (1.8 V or 3.3 V) are correct.
    6. For OTG micro‑AB, ID grounded: A‑device (host); ID floating: B‑device (peripheral). If the ID pin is floating, the PHY may not try to source VBUS.
    Alan
