Cyclone V FPGA HPS2FPGA Lightweight bridge timing requirement
I am working on developing the interface between the HPS and our FPGA design through the HPS2FPGA Lightweight bridge, which uses the AXI lite bus protocol. This protocol includes some handshaking control between the master and the slave. I have made some progress and am able to write to a register in the FPGA. However, the write operation cannot be completed. It appears that the HPS is waiting for confirmation. I used Quartus SignalTap (a software logic analyzer) to analyze the timing and found that my design module does send the confirmation to the HPS. Most likely, the problem is caused by some timing requirements for the HPS. I can’t find a document that explains the detailed timing requirements about this interface. I would greatly appreciate your feedback Thanks, Peter.
I hope to understand the timing requirements for following signals:
output wire [11:0] hps_0_h2f_lw_axi_master_awid, // hps_0_h2f_lw_axi_master.awid
output wire [20:0] hps_0_h2f_lw_axi_master_awaddr, // .awaddr
output wire [3:0] hps_0_h2f_lw_axi_master_awlen, // .awlen
output wire [2:0] hps_0_h2f_lw_axi_master_awsize, // .awsize
output wire [1:0] hps_0_h2f_lw_axi_master_awburst, // .awburst
output wire [1:0] hps_0_h2f_lw_axi_master_awlock, // .awlock
output wire [3:0] hps_0_h2f_lw_axi_master_awcache, // .awcache
output wire [2:0] hps_0_h2f_lw_axi_master_awprot, // .awprot
output wire hps_0_h2f_lw_axi_master_awvalid, // .awvalid
input wire hps_0_h2f_lw_axi_master_awready, // .awready
output wire [11:0] hps_0_h2f_lw_axi_master_wid, // .wid
output wire [31:0] hps_0_h2f_lw_axi_master_wdata, // .wdata
output wire [3:0] hps_0_h2f_lw_axi_master_wstrb, // .wstrb
output wire hps_0_h2f_lw_axi_master_wlast, // .wlast
output wire hps_0_h2f_lw_axi_master_wvalid, // .wvalid
input wire hps_0_h2f_lw_axi_master_wready, // .wready
input wire [11:0] hps_0_h2f_lw_axi_master_bid, // .bid
input wire [1:0] hps_0_h2f_lw_axi_master_bresp, // .bresp
input wire hps_0_h2f_lw_axi_master_bvalid, // .bvalid
output wire hps_0_h2f_lw_axi_master_bready, // .bready
output wire [11:0] hps_0_h2f_lw_axi_master_arid, // .arid
output wire [20:0] hps_0_h2f_lw_axi_master_araddr, // .araddr
output wire [3:0] hps_0_h2f_lw_axi_master_arlen, // .arlen
output wire [2:0] hps_0_h2f_lw_axi_master_arsize, // .arsize
output wire [1:0] hps_0_h2f_lw_axi_master_arburst, // .arburst
output wire [1:0] hps_0_h2f_lw_axi_master_arlock, // .arlock
output wire [3:0] hps_0_h2f_lw_axi_master_arcache, // .arcache
output wire [2:0] hps_0_h2f_lw_axi_master_arprot, // .arprot
output wire hps_0_h2f_lw_axi_master_arvalid, // .arvalid
input wire hps_0_h2f_lw_axi_master_arready, // .arready
input wire [11:0] hps_0_h2f_lw_axi_master_rid, // .rid
input wire [31:0] hps_0_h2f_lw_axi_master_rdata, // .rdata
input wire [1:0] hps_0_h2f_lw_axi_master_rresp, // .rresp
input wire hps_0_h2f_lw_axi_master_rlast, // .rlast
input wire hps_0_h2f_lw_axi_master_rvalid, // .rvalid
output wire hps_0_h2f_lw_axi_master_rready, // .rready
- aikeu
Hi Peter78759,
I think this rocketboards link may help for your issue:
https://forum.rocketboards.org/t/qsys-logic-for-creating-a-hps2fpga-com/1411
Aik Eu
- aikeu
