Custom board on Cyclone V HPS SDRAM preloader test
- 1 year ago
The final result is that even with a fly-by routed topology there are no issue on both 1.5V and 1.35V DDR3 DDR3L.
The MT41K128M16 /w 1k page size shows no sanity issue on memtest stresapptest on distro.
UBOOT memory normal test also passed w/o any errors.
So after short testing we can only assume there are inherent bug on Quartus 18.1? or HPS IP.
No matter it is /w or /wo the board settings no drop no crash no stuck.
So the case ends here.
Original failed and forcing it run on 25MHz DDR die is MT41K256M16TW-107:P
Same bsp flow no dts modification no board settings changed.
As mentioned before Cyclone V HPS have no leveling so instead of using the full 32 bit two dies.
We only assembled one (lower data bus 0-15).
And the layout of the fly-by is lucky that the closest is low-data-bus die then high-data-bus die.
So if the farthest one is not populated and termination resistor should able to clean the remain traces.
FPGA -> DDR(0-15) -> DDR(16-31) -> Rtt
FPGA -> DDR(0-15) -> trace w/o any IC -> Rtt
Based on the above information:
We had tried another DDR die MT41K128M16JT-125:K and referencing the development board we got from other company.
They are using smaller one with page-size only 1k.
And we used low 300M setting on C8N device.
Result as follows:
After kept running it from cold to warm any every powerup will auto run 4 times to try boot but we clean out the uboot.img.
We cannot see any errors on "if (hps_emif_diag_test(SDRAM_TEST_NORMAL, 0, sdram_size) == 0)"
So why "MT41K256M16TW" could not works but "MT41K128M16JT" ??
Do the HPS EMIF have issue on page-size?
Why development board component also use only 128x16 die rather than norm 256x16?
U-Boot SPL 2013.01.01 (Jul 30 2025 - 13:11:01)
BOARD : Altera SOCFPGA Cyclone V Board
CLOCK: EOSC1 clock 50000 KHz
CLOCK: EOSC2 clock 50000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 600 MHz
CLOCK: DDR clock 300 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 50000 KHz
CLOCK: QSPI clock 2343 KHz
RESET: COLD
INFO : Watchdog enabled
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 256 MiB
SDRAM: Ensuring specified SDRAM size is correct ...passed
SDRAM: Running EMIF Diagnostic Test ...Passed
ALTERA DWMMC: 0
reading u-boot.img
spl: error reading image u-boot.img, err - -1
### ERROR ### Please RESET the board ###
RESET: WARM
SDRAM: 256 MiB
ALTERA DWMMC: 0
reading u-boot.img
RESET: WARM
SDRAM: 256 MiB
ALTERA DWMMC: 0
reading u-boot.img
RESET: WARM
SDRAM: 256 MiB
ALTERA DWMMC: 0
reading u-boot.img
RESET: COLD
SDRAM: 256 MiB
ALTERA DWMMC: 0
reading u-boot.img
RESET: WARM
SDRAM: 256 MiB
ALTERA DWMMC: 0
reading u-boot.img
RESET: WARM
SDRAM: 256 MiB
ALTERA DWMMC: 0
reading u-boot.img
RESET: WARM
SDRAM: 256 MiB
ALTERA DWMMC: 0
reading u-boot.img
RESET: COLD
SDRAM: 256 MiB
ALTERA DWMMC: 0
reading u-boot.img
RESET: WARM
SDRAM: 256 MiB
ALTERA DWMMC: 0
reading u-boot.img
RESET: WARM
SDRAM: 256 MiB
ALTERA DWMMC: 0
reading u-boot.img
RESET: WARM
SDRAM: 256 MiB
ALTERA DWMMC: 0
reading u-boot.img
RESET: COLD
SDRAM: 256 MiB
ALTERA DWMMC: 0
reading u-boot.img
