Critical bug in Linux version of Embedded Development Suite 19.1
I think that I found a bug in the embedded command shell of EDS. After a fresh install of EDS on Manjaro Linux I get the following error when executing embedded_command_shell.sh:
sh: symbol lookup error: /opt/altera/19.1/embedded/host_tools/altera/ds5_link/../../../host_tools/python/lib/libreadline.so.8: undefined symbol: PC
WARNING: DS-5 install not detected. SoC EDS may not function correctly without a DS-5 install.
Intel FPGA Embedded Command Shell
Version 19.1 [Build 670]
This indicates a dependency error in the library of EDS itself. Is this bug known? Is there way to fix this? 18.1 is working without any problems on my distro so it seems a software related bug.
Kind regards,
Edian
This issue is due to the compatibility of the tool with the dependencies of linux versions.
I will file a bug issue and there should be some investigation before a solution can be released. Please keep in mind this procedure might take some time.
Thank you
- EAnni
Update: The problem is fixed when replacing the "/embedded/host_tools/python" directory of 19.1 with the "/embedded/host_tools/python" directory of 18.1. Intel can you please look into this and fix this bug in the 19.1 EDS linux package? Kind regards.
- FawazJ_Altera
Thank you
- SurajKumar1
First of all check their linux version,then check compatibility tools and check GPU driver also check - SurajKumar1
- SurajKumar1
Saw the, Information to respective sir
