EAnni
6 years agoCritical bug in Linux version of Embedded Development Suite 19.1
I think that I found a bug in the embedded command shell of EDS. After a fresh install of EDS on Manjaro Linux I get the following error when executing embedded_command_shell.sh: sh: symbol lookup ...
- 6 years ago
This issue is due to the compatibility of the tool with the dependencies of linux versions.
I will file a bug issue and there should be some investigation before a solution can be released. Please keep in mind this procedure might take some time.
Thank you
EAnni
6 years agoUpdate: The problem is fixed when replacing the "/embedded/host_tools/python" directory of 19.1 with the "/embedded/host_tools/python" directory of 18.1. Intel can you please look into this and fix this bug in the 19.1 EDS linux package? Kind regards.
