EAnni
6 years agoCritical bug in Linux version of Embedded Development Suite 19.1
I think that I found a bug in the embedded command shell of EDS. After a fresh install of EDS on Manjaro Linux I get the following error when executing embedded_command_shell.sh: sh: symbol lookup ...
- 6 years ago
This issue is due to the compatibility of the tool with the dependencies of linux versions.
I will file a bug issue and there should be some investigation before a solution can be released. Please keep in mind this procedure might take some time.
Thank you
FawazJ_Altera
6 years agoHello,
Thank you
SurajKumar1
5 years agoFirst of all check their linux version,then check compatibility tools and check GPU driver also check
