symmt_Intel
2 years agoCreating an SD Card for the Intel Agilex® 7 SoC
This time, I'm writing about creating an SD card for the Intel Agilex® 7 SoC. The catalyst for this was the announcement of Intel® Agilex™ FPGAs (code named Sundance Mesa) Delivering Industry-Leading...
AlexFV3
2 years agoHi on step G ( when choosing Ubuntu ),
on this line: sudo rm -rf lib/modules/*
The contents of lib/modules are removed, but is no "modules" directory, why do you attempt to delete the contents of directory "modules"
Then on this line: sudo cp -r $LINUX_BIN/a53/modules/* lib/modules/
There's a directory called "modules" in a53, how did you build the contents of directory "a53", it is unclear as to where does the directory "modules" come from in directory a53.
mkdir rootfs-yocto && cd rootfs-yocto # Not needed if not building with Yocto sudo tar xf $LINUX_BIN/a53/core-image-minimal-agilex.tar.gz sudo rm -rf lib/modules/* sudo cp -r $LINUX_BIN/a53/modules/* lib/modules/ cd .. mkdir rootfs-ubuntu && cd rootfs-ubuntu sudo tar xf $LINUX_BIN/a53/ubuntu-base-20.04.5-base-arm64.tar.gz sudo rm -rf lib/modules/* sudo cp -r $LINUX_BIN/a53/modules/* lib/modules/ cd .. ln -s rootfs-ubuntu rootfs
