paulgeisler
1 month agoBSP generation for I2C
How do I get the BSP generator to generate code for the I2C that I added into the platform of the max10? It generates code for the JTAG but not the I2C. I made sure that I connected the SDA and SCL l...
- 26 days ago
Hi @paulgeisler
The I2C driver is missing because
i2c_0.csris not connected to the Nios Vdata_manager. The BSP adds a driver for each peripheral that the processor masters. Exporting SDA and SCL does not make that connection.In Platform Designer:
- Connect
intel_niosv_m_0.data_managertoi2c_0.csr. - Set Interface for transfer command FIFO and receive data FIFO accesses to Avalon-MM Agent. In that mode the streaming ports are unused, so leave
rx_data_sourceandtransfer_command_sinkunconnected. - Connect
i2c_0.interrupt_sendertoplatform_irq_rxwhen you want interrupt-driven transfers. The driver is still added from thecsrconnection. The interrupt routines are optional. - Generate the HDL, then generate the BSP again.
altera_avalon_i2cshould appear in the BSP, with an initialization entry fori2c_0inalt_sys_init.c.
For the pins,
sda_inandsda_oeneed one bidirectional open-drain buffer, andscl_inandscl_oeneed another, instantiated in the top-level design. Assigning those four ports directly to FPGA pins leaves them as separate inputs and outputs.Best Wishes
- Connect
paulgeisler
1 month agoAdding one more screenshot.
