ARM DS USB BLASTER or USB BLASTER II ?
- 2 years ago
UPDATE 07/13/2024:
After an endless series of tests I finally understood that the problem was simply the fact that I was trying to debug an application compiled to run on the DDR SDRAM, without having initialized the DDR via u-boot!
Now I can debug ARM DS with both USB-Blaster-II and USB-BLASTER-I (both work)!
Now I'm trying to understand if there is a driver for ETHERNET that I can use in BARE-METAL mode.
Does Intel's HWLIB have this driver for CYCLONE V SoC?
Regards, Luca.
Hi GOMEZ_IT,
I’m glad that your question has been addressed, I now transition this thread to community support. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
- GOMEZ_IT2 years ago
I wanted to inform you that I purchased the USB Blaster II,
but unfortunately the problem has remained unchanged.I also wanted to ask if there is a step by step guide to be able to compile and debug bare-metal
on the cyclonev soc with the arm ds software (not arm-ds5 which is declared obsolete!).
I would like to be able to use the Boot-Rom - > Preloader -> BareMetal-App configuration - GOMEZ_IT2 years ago
UPDATE 07/13/2024:
Regards, Luca.
