서박사's avatar
서박사
4 years ago
ALTERA function fails after execution at C program
I'm using DE1-SoC with lubuntu 16.04.
I'm trying to make a C program to access the HPS resources such as LED, GPIO, etc.
I was using the kernel from Terasic, and the C program with altera functions (e.g. alt_write_word) to access the HPS resources could be successfully executed.
However, from someday, the kernel was corrupted by an unknown reason and the kernel from Terasic was also not working. (The U-boot failed after "Starting Kernel...")
So I replaced zImage file from Terasic resource to ghrd provided by releases.rocketboards.org and I could boot the FPGA successfully.
(rbf file was not replaced)
However, the terminal through the serial communication freezes after executing C program with altera functions.
That is, the terminal does not show any further logs and does not respond to any commands such as CTRL-C when I run the program with altera functions.
I've checked that the program without altera functions (such as, Hello World!) can be successfully executed.
Although the terminal freezes, I can still see the RXD LED blinking if I type the keyboard (i.e. sending data to FPGA HPS)
Is there any idea to debug this kind of error?
  • Hello서박사,
    I’m glad that your problem has been fixed.
    So I will close this thread if no further questions from you.
    Yoshiaki Saito
  • Hello서박사,
    Yoshiaki Saito
  • 서박사's avatar
    서박사
    Hello Yoshiaki,
    Thank you for your prompt response and the suggestion!
    I've tried to use memtool from the above link but failed to cross-compile it since my cross-compile environment doesn't have autoconfigure
    So I used another source code from the site below to compile memtool:
    https://gist.github.com/mike0/2910170
    Unfortunately, the read/write operation from/to certain registers (especially, FPGA-related registers) fail.
    TChat is, the terminal does not respond to any commands like case the above.
    I tried following commands (1 word = 32 bit):
    #1
    memtool FF001000 1 (read 1 word from 0xFF001000)
    Reading 0x1 count starting at address 0xFF001000
    0xFF001000: 00000000
    #2
    memtool FF200000 2 (read 2 words from 0xFF200000, while 0xFF200000 means LEDR)
    Reading 0x3 count starting at address 0xFF000000
    (freezes)
    #3
    memtool FF200020=16 (write 32bit word 16 to 0xFF200020, while 0xFF200020 means 7-segment displays register)
    Writing 32-bit value 0x16 to address 0xFF200020
    (freezes)
    #4
    memtool FFFEC600 3 (read 3 words from 0xFFFEC600, while 0xFFFEC600 means ARM A9 Private Timer)
    Reading 0x3 count starting at address 0xFFFEC600
    0xFFFEC600: 00234934 00165135 00000005
    #5
    memtool FFFEC600 3 (read 3 words again from 0xFFFEC600)
    0xFFFEC600: 00234934 00138EB5 00000005
    The addresses of the registers are based on DE1-SoC_Computer_ARM.pdf
    From the above result, should I suppose the FPGA hardware malfunction?
    + More logs using memtool
    #6
    memtool FFD0501C 3 (read 3 words from 0xFFD0501C, while 0xFFD0501C means FPGA Bridge)
    Reading 0x3 count starting at address 0xFFD0501C
    [ 68.718423] 8<--- cut here ---
    [ 68.725699] Unhandled fault: external abort on non-linefetch (0x1018) at 0xb6f0c024
    [ 68.733491] pgd = 64d55855
    [ 68.736193] [b6f0c024] *pgd=3ffb8831
    Bus error (core dumped)
    #7
    memtool C0000000 1 (read 1 words from 0xC0000000, while 0xC0000000 means SDRAM)
    Reading 0x1 count starting at address 0xC0000000
    (freezes)
    • YoshiakiS_Altera's avatar
      YoshiakiS_Altera
      Hello 서박사,
      Thank you for sharing the logs with us.
      First of all, you need to confirm Cyclone V SoC register map below.
      Cyclone V HPS Register Address Map and Definitions
      https://www.intel.com/content/www/us/en/programmable/hps/cyclone-v/hps.html#sfo1418687413697.html
      In case of #6, FFD0501C and FFD05020 are valid. But FFD05024 is undefined.
      If you access undefined area, AXI bus might response SLVERR or DECERR.
      The error will cause Bus Error.
      In case of the freezes, could you please try these addresses using 'md' command on U-boot?
      If you encounter an error, HPS2FPGA and Lightweight HPS2FPGA bridges might be disabled.
      Please check brgmodrst register (0xffd0501c).
      The bridges should be enabled on U-Boot.
      Yoshiaki Saito
      • 서박사's avatar
        서박사
        Hello Yoshiaki,
        Thank you again for your suggestion.
        I've checked the register at the address 0xffd0501c and at the address FF200000 and got the result as follows:
        Booting log
        U-Boot 2013.01.01 (Oct 12 2016 - 10:40:34)
        CPU : Altera SOCFPGA Platform
        BOARD : Altera SOCFPGA Cyclone V Board
        I2C: ready
        DRAM: 1 GiB
        MMC: ALTERA DWMMC: 0
        *** Warning - bad CRC, using default environment
        In: serial
        Out: serial
        Err: serial
        Skipped ethaddr assignment due to invalid EMAC address in EEPROM
        Net: mii0
        Warning: failed to set MAC address
        Hit any key to stop autoboot: 0
        SOCFPGA_CYCLONE5 # md.w FFD05020 2
        ffd05020: 0000 0000 ....
        SOCFPGA_CYCLONE5 # md.w FF200000 1
        ff200000:
        (freeze)
        As far as I know, if the last 3 bit is low (0), the bridges are enabled.
        I've also checked that if FPGA itself is not working properly through operating the FPGA in active-serial mode, but I found that the operation of the FPGA is not the issue.
        Please let me know if there is any other method to debug this error.
        I appreciate your time and effort. Thank you!
    YoshiakiS_Altera
    Hello 서박사,
    Thank you for the update.
    The address of Bridge enable register below is 0xffd0501c, not 0xffd05020.
    https://www.intel.com/content/www/us/en/programmable/hps/cyclone-v/hps.html#sfo1410067767967.html
    Next, you should use correct access size for I/O register, not memory.
    For I/O register, the access size is important. If you use wrong size, a result of the access will be unpredicted.
    In case of 0xffd0501c, you should use md.l or md command due to 32bit register, not md.w.
    Please check the status by typing “md ffd0501c 1”.
    Lastly, is it possible that you can share the .qsys file with us just in case?
    Yoshiaki Saito
    • 서박사's avatar
      서박사
      Hello Yoshiaki,
      Sorry for the wrong logs for accessing the data register.
      I've checked the value at the register which corresponds to the HPS-FPGA bridge changes properly while U-Boot, and the logs are as follows:
      commands and logs
      U-Boot SPL 2013.01.01 (Oct 12 2016 - 10:38:03)
      CLOCK: EOSC1 clock 25000 KHz
      CLOCK: EOSC2 clock 25000 KHz
      CLOCK: F2S_SDR_REF clock 0 KHz
      CLOCK: F2S_PER_REF clock 0 KHz
      CLOCK: MPU clock 925 MHz
      CLOCK: DDR clock 400 MHz
      CLOCK: UART clock 100000 KHz
      CLOCK: MMC clock 50000 KHz
      CLOCK: QSPI clock 3613 KHz
      RESET: WARM
      INFO : Watchdog enabled
      SDRAM: Initializing MMR registers
      SDRAM: Calibrating PHY
      SEQ.C: Preparing to start memory calibration
      SEQ.C: CALIBRATION PASSED
      SDRAM: 1024 MiB
      ALTERA DWMMC: 0
      I2C: ready
      DRAM: 1 GiB
      In: serial
      Out: serial
      Err: serial
      Net: mii0
      SOCFPGA_CYCLONE5 # fatload mmc 0:1 $fpgadata soc_system.rbf;
      reading soc_system.rbf
      7007204 bytes read in 358 ms (18.7 MiB/s)
      SOCFPGA_CYCLONE5 # fpga load 0 $fpgadata $filesize;
      SOCFPGA_CYCLONE5 # md FFD0501C 1
      ffd0501c: 00000007 ....
      SOCFPGA_CYCLONE5 # run bridge_enable_handoff;
      ## Starting application at 0x3FF795A4 ...
      ## Application terminated, rc = 0x0
      ffd0501c: 00000000 ....
      SOCFPGA_CYCLONE5 # run mmcload;
      reading zImage
      5676720 bytes read in 286 ms (18.9 MiB/s)
      reading socfpga.dtb
      31245 bytes read in 8 ms (3.7 MiB/s)
      SOCFPGA_CYCLONE5 # run mmcboot;
      ## Flattened Device Tree blob at 00000100
      Booting using the fdt blob at 0x00000100
      reserving fdt memory region: addr=0 size=1000
      Loading Device Tree to 03ff5000, end 03fffa0c ... OK
      Starting kernel ...
      In addition, .qsys file is compressed to .7z file and attached this reply, so please find it.
      It is based on the project "DE1-SoC_Computer " which is provided by Altera University Program.
      The .rbf file is based on the attached .qsys file, .dtb file is based on the Terasic Ubuntu image and zImage is provided by releases.rocketboards.org.
      I've tried to use all files from Terasic Ubuntu image, but in this case, I couldn't boot the device.
      For your information, .dtb file and zImage file are also attached to this reply.
      Thank you for your devotion!!
  • Hello 서박사,
    I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
    Thank you.
