ALTERA function fails after execution at C program
- 4 years ago
Hello서박사,
I’m glad that your problem has been fixed.
So I will close this thread if no further questions from you.
Yoshiaki Saito
Hello Yoshiaki,
Sorry for the wrong logs for accessing the data register.
I've checked the value at the register which corresponds to the HPS-FPGA bridge changes properly while U-Boot, and the logs are as follows:
commands and logs
U-Boot SPL 2013.01.01 (Oct 12 2016 - 10:38:03)
BOARD : Altera SOCFPGA Cyclone V Board
CLOCK: EOSC1 clock 25000 KHz
CLOCK: EOSC2 clock 25000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 925 MHz
CLOCK: DDR clock 400 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 50000 KHz
CLOCK: QSPI clock 3613 KHz
RESET: WARM
INFO : Watchdog enabled
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 1024 MiB
ALTERA DWMMC: 0
U-Boot 2013.01.01 (Oct 12 2016 - 10:40:34)
CPU : Altera SOCFPGA Platform
I2C: ready
DRAM: 1 GiB
MMC: ALTERA DWMMC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Skipped ethaddr assignment due to invalid EMAC address in EEPROM
Net: mii0
Warning: failed to set MAC address
Hit any key to stop autoboot: 0
SOCFPGA_CYCLONE5 # fatload mmc 0:1 $fpgadata soc_system.rbf;
reading soc_system.rbf
7007204 bytes read in 358 ms (18.7 MiB/s)
SOCFPGA_CYCLONE5 # fpga load 0 $fpgadata $filesize;
SOCFPGA_CYCLONE5 # md FFD0501C 1
ffd0501c: 00000007 ....
SOCFPGA_CYCLONE5 # run bridge_enable_handoff;
## Starting application at 0x3FF795A4 ...
## Application terminated, rc = 0x0
ffd0501c: 00000000 ....
SOCFPGA_CYCLONE5 # run mmcload;
reading zImage
5676720 bytes read in 286 ms (18.9 MiB/s)
reading socfpga.dtb
31245 bytes read in 8 ms (3.7 MiB/s)
SOCFPGA_CYCLONE5 # run mmcboot;
## Flattened Device Tree blob at 00000100
Booting using the fdt blob at 0x00000100
reserving fdt memory region: addr=0 size=1000
Loading Device Tree to 03ff5000, end 03fffa0c ... OK
Starting kernel ...
In addition, .qsys file is compressed to .7z file and attached this reply, so please find it.
It is based on the project "DE1-SoC_Computer " which is provided by Altera University Program.
The .rbf file is based on the attached .qsys file, .dtb file is based on the Terasic Ubuntu image and zImage is provided by releases.rocketboards.org.
I've tried to use all files from Terasic Ubuntu image, but in this case, I couldn't boot the device.
For your information, .dtb file and zImage file are also attached to this reply.
Thank you for your devotion!!
Hello Hi서박사,
Basically, you should build DTB from DTS in same Kernel tree.
So could you please try the latest Linux Ubuntu Desktop(2016-12-28) in new SD-CARD again just in case?
Lastly, Bus size of LED is 32 bit as below. You should use md.l or md command to access the port instead of md.w.
2.3.1 Red LED Parallel Port
Yoshiaki Saito
- 서박사4 years ago
Hello Yoshiaki,
Thank you for the answer.
Using the latest Linux Ubuntu Desktop (v1.0, 2016-12-28) from Terasic resource center, U-boot fails with the following logs.
Booting log:
RESET: COLD
SDRAM: 1024 MiB
ALTERA DWMMC: 0
U-Boot 2013.01.01 (Oct 12 2016 - 10:40:34)CPU : Altera SOCFPGA Platform
I2C: ready
DRAM: 1 GiB
*** Warning - bad CRC, using default environmentIn: serial
Out: serial
Err: serial
Net: mii0
Warning: failed to set MAC addressHit any key to stop autoboot: 0
reading u-boot.scr
200 bytes read in 4 ms (48.8 KiB/s)
## Executing script at 02000000
7007184 bytes read in 327 ms (20.4 MiB/s)
reading zImage
5538512 bytes read in 257 ms (20.6 MiB/s)
reading socfpga.dtb
31245 bytes read in 6 ms (5 MiB/s)
Loading Device Tree to 03ff5000, end 03fffa0c ... OKStarting kernel ...
In addition, 32bit read of the register also fails with the logs as follows:
logs:
RESET: COLD
SDRAM: 1024 MiB
ALTERA DWMMC: 0
I2C: ready
DRAM: 1 GiB
Out: serial
Err: serial
Net: mii0
7007204 bytes read in 361 ms (18.5 MiB/s)
reading zImage
reading socfpga.dtb
SOCFPGA_CYCLONE5 # md FF200000 1
ff200000:(freezes)
I really appreciate your time and effort on this thread.
Thank you!
- 서박사4 years ago
I think I found the error source and fixed it.
The main reason was the malfunction of the clock source at the FPGA.
In the attached .qsys file, almost all FPGA components are based on the output clock of the PLL, which reference clock is provided by PIN_AF14.
However, I found that this clock source is not working.
I revised the system configuration to take a clock source from PIN_K14, not from PIN_AF14.
Thus, everything works well.
The logs are as follows:
root@DE1_SoC:~> ./memtool FFD0501C 1
Reading 0x1 count starting at address 0xFFD0501C0xFFD0501C: 00000000
root@DE1_SoC:~> ./memtool FF200000 1
Reading 0x1 count starting at address 0xFF2000000xFF200000: 000003FF (This result is intended)
I'm sorry for making this thread to be too long since I'm not familiar with the embedded system, including FPGA.
And again, I really appreciate your time and effort on this issue.
Thank you!!
