Hello Yoshiaki,
Thank you again for your suggestion.
I've checked the register at the address 0xffd0501c and at the address FF200000 and got the result as follows:
Booting log
U-Boot 2013.01.01 (Oct 12 2016 - 10:40:34)
CPU : Altera SOCFPGA Platform
BOARD : Altera SOCFPGA Cyclone V Board
I2C: ready
DRAM: 1 GiB
MMC: ALTERA DWMMC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Skipped ethaddr assignment due to invalid EMAC address in EEPROM
Net: mii0
Warning: failed to set MAC address
Hit any key to stop autoboot: 0
SOCFPGA_CYCLONE5 # md.w FFD05020 2
ffd05020: 0000 0000 ....
SOCFPGA_CYCLONE5 # md.w FF200000 1
ff200000:
(freeze)
As far as I know, if the last 3 bit is low (0), the bridges are enabled.
I've also checked that if FPGA itself is not working properly through operating the FPGA in active-serial mode, but I found that the operation of the FPGA is not the issue.
Please let me know if there is any other method to debug this error.
I appreciate your time and effort. Thank you!
