rdrr's avatar
rdrr
5 months ago
Agilex 5 with HPS
I have a question regarding Agilex 5 with HPS.
I intend to deliver to the client a device based on Agilex 5 and HPS, but initially the HPS must remain fully offline. In other words, once the device is shipped, I need to ensure with 100% certainty that no software or program can be executed on the HPS, and that there is no possible way for the client to interact with or enable it prematurely.
At the same time, I need to retain the ability to remotely deploy a new FPGA bitstream at a later stage, which will enable the HPS once the HPS software development is completed.
Is such a workflow achievable on this platform?
  • Dear rdrr,
    Greetings, as we do not receive any further clarification/updates on the matter, hence would assume challenge are overcome. We will continue to monitor this post for the next 5 days. If there are no further inquiries during this period, I will step back and allow the community to assist with any future follow-up questions.
    Altera Technical Support
  • The workflow I would recommend here is to enable Bitstream Authentication (https://www.intel.com/content/www/us/en/docs/programmable/683039/25-1-1/enabling-bitstream-security-for-and-devices.html) which will then require that only bitstreamed signed by you can be loaded on the device. Using this scheme you can control that the HPS will always be off by virtue of the designs you create.
    • BoonBengT_Altera's avatar
      BoonBengT_Altera
      Icon for Moderator rankModerator
      Hi rdrr ,
      I hope you’re doing well. I wanted to follow up and check if there are any remaining questions or concerns regarding this matter. Please let us know if anything still needs clarification — we’re happy to assist further.
      Thank you for your time, and we look forward to your feedback.
      Best Wishes
      BB
  • Hi rdrr,
    The HPS boots off of code that is inserted into the HPS OCRAM by the SDM during the configuration process.  The OCRAM does not retain contents when power is not applied.
    You can use the HPS to update the FPGA with a new bitstream using Remote System Update. Please see this example for more information.
    Sue
