KianHinT_altera
1 month agoThanks Erica for the advice on this issue.
Hi Sarah,
Since you mention that Linux is working and the OS that you're using is not, as Erica mentioned, I would suspect the device tree is not set properly for your OS, could you check on this first to see whether it is configured correctly, probably you can compare with the Linux since that is working.
Kian
