Agilex 5 EMAC to EMAC : Driver error
- 1 year ago
Solved: bring MAC signals up a module
The fact that gmac2 works, while gmac0/gmac1 fail with identical setup, strongly suggests-> The reset lines for EMAC0 and EMAC1 are not wired or released correctly in the FPGA handoff.
The Linux kernel attempts to reset the DMA via
resets = <&rst EMAC0_RESET>, <&rst EMAC0_OCP_RESET>;
But these don't actually trigger a reset, leave the DMA in a bad state.
Try a simple test, comment out the resets for gmac0:
// resets = <&rst EMAC0_RESET>, <&rst EMAC0_OCP_RESET>;
// reset-names = "stmmaceth", "stmmaceth-ocp";
Recompile and reboot. If this makes the error go away (or lets the DMA at least initialize), the reset was the issue.
Thanks for this suggestion! However it seems that this does not solve the issue. I would be interested to see the rest of the snippet you shared on 06-20-2025. Is that possible?
