K606
Contributor
1 year agoAgilex 5 EMAC to EMAC : Driver error
I am trying to ping one EMAC from another, and have instantiated the following in the HPS: These are exported to the top level, then connected as followed: // https://www.intel.com/content/...
- 1 year ago
Solved: bring MAC signals up a module
K606
Contributor
1 year agoHi thanks for the resources!
yes no problem, here is the .dtsi:
// SPDX-License-Identifier: GPL-2.0 /* * Copyright (C) 2023, Intel Corporation */ /dts-v1/; #include <dt-bindings/reset/altr,rst-mgr-agilex5.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/interrupt-controller/arm-gic.h> #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/clock/agilex5-clock.h> / { compatible = "intel,socfpga-agilex"; #address-cells = <2>; #size-cells = <2>; reserved-memory { #address-cells = <2>; #size-cells = <2>; ranges; service_reserved: svcbuffer@0 { compatible = "shared-dma-pool"; reg = <0x0 0x80000000 0x0 0x2000000>; alignment = <0x1000>; no-map; }; }; cpus { #address-cells = <1>; #size-cells = <0>; cpu0: cpu@0 { compatible = "arm,cortex-a55"; device_type = "cpu"; enable-method = "psci"; reg = <0x0>; next-level-cache = <&L2>; }; cpu1: cpu@1 { compatible = "arm,cortex-a55"; device_type = "cpu"; enable-method = "psci"; reg = <0x100>; next-level-cache = <&L2>; }; cpu2: cpu@2 { compatible = "arm,cortex-a76"; device_type = "cpu"; enable-method = "psci"; reg = <0x200>; next-level-cache = <&L2>; }; cpu3: cpu@3 { compatible = "arm,cortex-a76"; device_type = "cpu"; enable-method = "psci"; reg = <0x300>; next-level-cache = <&L2>; }; L2: l2-cache { compatible = "cache"; cache-level = <2>; next-level-cache = <&L3>; }; L3: l3-cache { compatible = "cache"; }; }; psci { compatible = "arm,psci-0.2"; method = "smc"; }; intc: interrupt-controller@1d000000 { compatible = "arm,gic-v3", "arm,cortex-a15-gic"; #interrupt-cells = <3>; #address-cells = <2>; #size-cells =<2>; interrupt-controller; #redistributor-regions = <1>; label = "GIC"; status = "okay"; ranges; redistributor-stride = <0x0 0x20000>; reg = <0x0 0x1d000000 0 0x10000>, <0x0 0x1d060000 0 0x100000>; its: msi-controller@1d040000 { compatible = "arm,gic-v3-its"; reg = <0x0 0x1d040000 0x0 0x20000>; label = "ITS"; msi-controller; status = "okay"; }; }; /* Clock tree 5 main sources*/ clocks { cb_intosc_hs_div2_clk: cb-intosc-hs-div2-clk { #clock-cells = <0>; compatible = "fixed-clock"; }; cb_intosc_ls_clk: cb-intosc-ls-clk { #clock-cells = <0>; compatible = "fixed-clock"; }; f2s_free_clk: f2s-free-clk { #clock-cells = <0>; compatible = "fixed-clock"; }; osc1: osc1 { #clock-cells = <0>; compatible = "fixed-clock"; }; qspi_clk: qspi-clk { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <200000000>; }; }; timer { compatible = "arm,armv8-timer"; interrupt-parent = <&intc>; interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; }; usbphy0: usbphy { #phy-cells = <0>; compatible = "usb-nop-xceiv"; }; pmu { compatible = "arm,armv8-pmuv3"; interrupt-parent = <&intc>; interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_LOW>; cpus = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; }; soc { #address-cells = <1>; #size-cells = <1>; compatible = "simple-bus"; device_type = "soc"; interrupt-parent = <&intc>; ranges = <0 0 0 0xffffffff>; base_fpga_region { #address-cells = <0x2>; #size-cells = <0x2>; compatible = "fpga-region"; fpga-mgr = <&fpga_mgr>; }; clkmgr: clock-controller@10d10000 { compatible = "intel,agilex5-clkmgr"; reg = <0x10d10000 0x1000>; #clock-cells = <1>; }; gmac0: ethernet@10810000 { compatible = "altr,socfpga-stmmac-a10-s10", "snps,dwxgmac-2.10", "snps,dwxgmac"; reg = <0x10810000 0x3500>; interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 191 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 192 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 193 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 194 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 195 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 196 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 197 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 198 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 199 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 202 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 203 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 204 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 205 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 206 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "macirq", "macirq_tx0", "macirq_tx1", "macirq_tx2", "macirq_tx3", "macirq_tx4", "macirq_tx5", "macirq_tx6", "macirq_tx7", "macirq_rx0", "macirq_rx1", "macirq_rx2", "macirq_rx3", "macirq_rx4", "macirq_rx5", "macirq_rx6", "macirq_rx7"; resets = <&rst EMAC0_RESET>, <&rst EMAC0_OCP_RESET>; reset-names = "stmmaceth", "stmmaceth-ocp"; clocks = <&clkmgr AGILEX5_EMAC0_CLK>, <&clkmgr AGILEX5_EMAC_PTP_CLK>; clock-names = "stmmaceth", "ptp_ref"; mac-address = [00 00 00 00 00 00]; tx-fifo-depth = <32768>; rx-fifo-depth = <16384>; snps,multicast-filter-bins = <64>; snps,perfect-filter-entries = <64>; snps,axi-config = <&stmmac_axi_emac0_setup>; snps,mtl-rx-config = <&mtl_rx_emac0_setup>; snps,mtl-tx-config = <&mtl_tx_emac0_setup>; snps,pbl = <32>; snps,pblx8; snps,multi-irq-en; snps,tso; snps,rx-vlan-offload; altr,sysmgr-syscon = <&sysmgr 0x44 0>; altr,smtg-hub; iommus = <&smmu 1>; status = "disabled"; stmmac_axi_emac0_setup: stmmac-axi-config { snps,wr_osr_lmt = <31>; snps,rd_osr_lmt = <31>; snps,blen = <0 0 0 32 16 8 4>; }; mtl_rx_emac0_setup: rx-queues-config { snps,rx-queues-to-use = <8>; snps,rx-sched-sp; queue0 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x0>; }; queue1 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x1>; }; queue2 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x2>; }; queue3 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x3>; }; queue4 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x4>; }; queue5 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x5>; }; queue6 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x6>; }; queue7 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x7>; }; }; mtl_tx_emac0_setup: tx-queues-config { snps,tx-queues-to-use = <8>; snps,tx-queues-with-coe = <2>; snps,tx-sched-wrr; queue0 { snps,weight = <0x09>; snps,dcb-algorithm; }; queue1 { snps,weight = <0x0A>; snps,dcb-algorithm; }; queue2 { snps,weight = <0x0B>; snps,dcb-algorithm; }; queue3 { snps,weight = <0x0C>; snps,dcb-algorithm; }; queue4 { snps,weight = <0x0D>; snps,dcb-algorithm; }; queue5 { snps,weight = <0x0E>; snps,dcb-algorithm; }; queue6 { snps,weight = <0x0F>; snps,dcb-algorithm; snps,tbs-enable; }; queue7 { snps,weight = <0x10>; snps,dcb-algorithm; snps,tbs-enable; }; }; }; gmac1: ethernet@10820000 { compatible = "altr,socfpga-stmmac-a10-s10", "snps,dwxgmac-2.10", "snps,dwxgmac"; reg = <0x10820000 0x3500>; interrupts = <GIC_SPI 207 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 208 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 209 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 210 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 211 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 212 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 213 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 214 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 215 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 216 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 217 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 218 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 219 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 220 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 221 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 222 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 223 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "macirq", "macirq_tx0", "macirq_tx1", "macirq_tx2", "macirq_tx3", "macirq_tx4", "macirq_tx5", "macirq_tx6", "macirq_tx7", "macirq_rx0", "macirq_rx1", "macirq_rx2", "macirq_rx3", "macirq_rx4", "macirq_rx5", "macirq_rx6", "macirq_rx7"; resets = <&rst EMAC1_RESET>, <&rst EMAC1_OCP_RESET>; reset-names = "stmmaceth", "stmmaceth-ocp"; clocks = <&clkmgr AGILEX5_EMAC1_CLK>, <&clkmgr AGILEX5_EMAC_PTP_CLK>; clock-names = "stmmaceth", "ptp_ref"; mac-address = [00 00 00 00 00 00]; tx-fifo-depth = <32768>; rx-fifo-depth = <16384>; snps,multicast-filter-bins = <64>; snps,perfect-filter-entries = <64>; snps,axi-config = <&stmmac_axi_emac1_setup>; snps,mtl-rx-config = <&mtl_rx_emac1_setup>; snps,mtl-tx-config = <&mtl_tx_emac1_setup>; snps,pbl = <32>; snps,pblx8; snps,multi-irq-en; snps,tso; snps,rx-vlan-offload; altr,sysmgr-syscon = <&sysmgr 0x48 0>; altr,smtg-hub; iommus = <&smmu 2>; status = "disabled"; stmmac_axi_emac1_setup: stmmac-axi-config { snps,wr_osr_lmt = <31>; snps,rd_osr_lmt = <31>; snps,blen = <0 0 0 32 16 8 4>; }; mtl_rx_emac1_setup: rx-queues-config { snps,rx-queues-to-use = <8>; snps,rx-sched-sp; queue0 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x0>; }; queue1 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x1>; }; queue2 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x2>; }; queue3 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x3>; }; queue4 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x4>; }; queue5 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x5>; }; queue6 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x6>; }; queue7 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x7>; }; }; mtl_tx_emac1_setup: tx-queues-config { snps,tx-queues-to-use = <8>; snps,tx-queues-with-coe = <2>; snps,tx-sched-wrr; queue0 { snps,weight = <0x09>; snps,dcb-algorithm; }; queue1 { snps,weight = <0x0A>; snps,dcb-algorithm; }; queue2 { snps,weight = <0x0B>; snps,dcb-algorithm; }; queue3 { snps,weight = <0x0C>; snps,dcb-algorithm; }; queue4 { snps,weight = <0x0D>; snps,dcb-algorithm; }; queue5 { snps,weight = <0x0E>; snps,dcb-algorithm; }; queue6 { snps,weight = <0x0F>; snps,dcb-algorithm; snps,tbs-enable; }; queue7 { snps,weight = <0x10>; snps,dcb-algorithm; snps,tbs-enable; }; }; }; gmac2: ethernet@10830000 { compatible = "altr,socfpga-stmmac-a10-s10", "snps,dwxgmac-2.10", "snps,dwxgmac"; reg = <0x10830000 0x3500>; interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 225 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 227 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 228 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 229 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 230 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 231 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 232 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 233 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 234 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 235 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 236 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 237 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 240 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "macirq", "macirq_tx0", "macirq_tx1", "macirq_tx2", "macirq_tx3", "macirq_tx4", "macirq_tx5", "macirq_tx6", "macirq_tx7", "macirq_rx0", "macirq_rx1", "macirq_rx2", "macirq_rx3", "macirq_rx4", "macirq_rx5", "macirq_rx6", "macirq_rx7"; resets = <&rst EMAC2_RESET>, <&rst EMAC2_OCP_RESET>; reset-names = "stmmaceth", "stmmaceth-ocp"; clocks = <&clkmgr AGILEX5_EMAC2_CLK>, <&clkmgr AGILEX5_EMAC_PTP_CLK>; clock-names = "stmmaceth", "ptp_ref"; mac-address = [00 00 00 00 00 00]; tx-fifo-depth = <32768>; rx-fifo-depth = <16384>; snps,multicast-filter-bins = <64>; snps,perfect-filter-entries = <64>; snps,axi-config = <&stmmac_axi_emac2_setup>; snps,mtl-rx-config = <&mtl_rx_emac2_setup>; snps,mtl-tx-config = <&mtl_tx_emac2_setup>; snps,pbl = <32>; snps,pblx8; snps,multi-irq-en; snps,tso; snps,rx-vlan-offload; altr,sysmgr-syscon = <&sysmgr 0x4c 0>; altr,smtg-hub; iommus = <&smmu 3>; status = "disabled"; stmmac_axi_emac2_setup: stmmac-axi-config { snps,wr_osr_lmt = <31>; snps,rd_osr_lmt = <31>; snps,blen = <0 0 0 32 16 8 4>; }; mtl_rx_emac2_setup: rx-queues-config { snps,rx-queues-to-use = <8>; snps,rx-sched-sp; queue0 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x0>; }; queue1 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x1>; }; queue2 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x2>; }; queue3 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x3>; }; queue4 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x4>; }; queue5 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x5>; }; queue6 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x6>; }; queue7 { snps,dcb-algorithm; snps,map-to-dma-channel = <0x7>; }; }; mtl_tx_emac2_setup: tx-queues-config { snps,tx-queues-to-use = <8>; snps,tx-queues-with-coe = <2>; snps,tx-sched-wrr; queue0 { snps,weight = <0x09>; snps,dcb-algorithm; }; queue1 { snps,weight = <0x0A>; snps,dcb-algorithm; }; queue2 { snps,weight = <0x0B>; snps,dcb-algorithm; }; queue3 { snps,weight = <0x0C>; snps,dcb-algorithm; }; queue4 { snps,weight = <0x0D>; snps,dcb-algorithm; }; queue5 { snps,weight = <0x0E>; snps,dcb-algorithm; }; queue6 { snps,weight = <0x0F>; snps,dcb-algorithm; snps,tbs-enable; }; queue7 { snps,weight = <0x10>; snps,dcb-algorithm; snps,tbs-enable; }; }; }; i2c0: i2c@10c02800 { #address-cells = <1>; #size-cells = <0>; compatible = "snps,designware-i2c"; reg = <0x10c02800 0x100>; interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; resets = <&rst I2C0_RESET>; clocks = <&clkmgr AGILEX5_L4_SP_CLK>; status = "disabled"; }; i2c1: i2c@10c02900 { #address-cells = <1>; #size-cells = <0>; compatible = "snps,designware-i2c"; reg = <0x10c02900 0x100>; interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; resets = <&rst I2C1_RESET>; clocks = <&clkmgr AGILEX5_L4_SP_CLK>; status = "disabled"; }; i2c2: i2c@10c02a00 { #address-cells = <1>; #size-cells = <0>; compatible = "snps,designware-i2c"; reg = <0x10c02a00 0x100>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; resets = <&rst I2C2_RESET>; clocks = <&clkmgr AGILEX5_L4_SP_CLK>; status = "disabled"; }; i2c3: i2c@10c02b00 { #address-cells = <1>; #size-cells = <0>; compatible = "snps,designware-i2c"; reg = <0x10c02b00 0x100>; interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; resets = <&rst I2C3_RESET>; clocks = <&clkmgr AGILEX5_L4_SP_CLK>; status = "disabled"; }; i2c4: i2c@10c02c00 { #address-cells = <1>; #size-cells = <0>; compatible = "snps,designware-i2c"; reg = <0x10c02c00 0x100>; interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; resets = <&rst I2C4_RESET>; clocks = <&clkmgr AGILEX5_L4_SP_CLK>; status = "disabled"; }; i3c0: i3c@10da0000 { #address-cells = <1>; #size-cells = <0>; compatible = "snps,dw-i3c-master-1.00a"; reg = <0x10da0000 0x1000>; interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; resets = <&rst I3C0_RESET>; clocks = <&clkmgr AGILEX5_L4_MP_CLK>; status = "disabled"; }; i3c1: i3c@10da1000 { #address-cells = <1>; #size-cells = <0>; compatible = "snps,dw-i3c-master-1.00a"; reg = <0x10da1000 0x1000>; interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; resets = <&rst I3C1_RESET>; clocks = <&clkmgr AGILEX5_L4_MP_CLK>; status = "disabled"; }; gpio0: gpio@10c03200 { compatible = "snps,dw-apb-gpio"; reg = <0x10c03200 0x100>; #address-cells = <1>; #size-cells = <0>; resets = <&rst GPIO0_RESET>; status = "disabled"; porta: gpio-controller@0 { compatible = "snps,dw-apb-gpio-port"; reg = <0>; gpio-controller; #gpio-cells = <2>; snps,nr-gpios = <24>; interrupt-controller; #interrupt-cells = <2>; interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; }; }; gpio1: gpio@10C03300 { #address-cells = <1>; #size-cells = <0>; compatible = "snps,dw-apb-gpio"; reg = <0x10C03300 0x100>; resets = <&rst GPIO1_RESET>; status = "disabled"; portb: gpio-controller@0 { compatible = "snps,dw-apb-gpio-port"; gpio-controller; #gpio-cells = <2>; snps,nr-gpios = <24>; reg = <0>; interrupt-controller; #interrupt-cells = <2>; interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; }; }; mmc: mmc0@10808000 { #address-cells = <1>; #size-cells = <0>; compatible = "intel,agilex5-sd4hc", "cdns,sd4hc"; reg = <0x10808000 0x1000>; interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; fifo-depth = <0x800>; resets = <&rst SDMMC_RESET>; reset-names = "reset"; clocks = <&clkmgr AGILEX5_L4_MP_CLK>, <&clkmgr AGILEX5_SDMCLK>; clock-names = "biu", "ciu"; iommus = <&smmu 5>; status = "disabled"; }; nand: nand-controller@10b80000 { #address-cells = <1>; #size-cells = <0>; compatible = "cdns,hp-nfc"; reg = <0x10b80000 0x10000>, <0x10840000 0x1000>; reg-names = "reg", "sdma"; interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clkmgr AGILEX5_NAND_NF_CLK>; clock-names = "nf_clk"; cdns,board-delay-ps = <4830>; iommus = <&smmu 4>; status = "disabled"; }; ocram: sram@00000000 { compatible = "mmio-sram"; reg = <0x00000000 0x80000>; }; dmac0: dma-controller@10DB0000 { compatible = "snps,axi-dma-1.01a"; reg = <0x10DB0000 0x500>; clocks = <&clkmgr AGILEX5_L4_MAIN_CLK>, <&clkmgr AGILEX5_L4_MP_CLK>; clock-names = "core-clk", "cfgr-clk"; interrupt-parent = <&intc>; interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; #dma-cells = <1>; dma-channels = <4>; snps,dma-masters = <1>; snps,data-width = <3>; snps,block-size = <32767 32767 32767 32767>; snps,priority = <0 1 2 3>; snps,axi-max-burst-len = <8>; snps,dma-40-bit-mask; iommus = <&smmu 8>; status = "okay"; }; dmac1: dma-controller@10DC0000 { compatible = "snps,axi-dma-1.01a"; reg = <0x10DC0000 0x500>; clocks = <&clkmgr AGILEX5_L4_MAIN_CLK>, <&clkmgr AGILEX5_L4_MP_CLK>; clock-names = "core-clk", "cfgr-clk"; interrupt-parent = <&intc>; interrupts = <GIC_SPI 171 IRQ_TYPE_LEVEL_HIGH>; #dma-cells = <1>; dma-channels = <4>; snps,dma-masters = <1>; snps,data-width = <3>; snps,block-size = <32767 32767 32767 32767>; snps,priority = <0 1 2 3>; snps,axi-max-burst-len = <8>; snps,dma-40-bit-mask; iommus = <&smmu 9>; status = "okay"; }; rst: rstmgr@10d11000 { #reset-cells = <1>; compatible = "altr,stratix10-rst-mgr"; reg = <0x10d11000 0x100>; }; smmu: iommu@16000000 { compatible = "arm,smmu-v3"; reg = <0x16000000 0x30000>; interrupts = <GIC_SPI 134 IRQ_TYPE_EDGE_RISING>, <GIC_SPI 129 IRQ_TYPE_EDGE_RISING>, <GIC_SPI 132 IRQ_TYPE_EDGE_RISING>; interrupt-names = "eventq", "gerror", "priq"; dma-coherent; #iommu-cells = <1>; status = "disabled"; }; spi0: spi@10da4000 { compatible = "snps,dw-apb-ssi"; #address-cells = <1>; #size-cells = <0>; reg = <0x10da4000 0x1000>; interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; resets = <&rst SPIM0_RESET>; reset-names = "spi"; reg-io-width = <4>; num-cs = <4>; clocks = <&clkmgr AGILEX5_L4_MAIN_CLK>; dmas = <&dmac0 16>, <&dmac0 17>; dma-names ="tx", "rx"; status = "disabled"; }; spi1: spi@10da5000 { compatible = "snps,dw-apb-ssi"; #address-cells = <1>; #size-cells = <0>; reg = <0x10da5000 0x1000>; interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; resets = <&rst SPIM1_RESET>; reset-names = "spi"; reg-io-width = <4>; num-cs = <4>; clocks = <&clkmgr AGILEX5_L4_MAIN_CLK>; dmas = <&dmac0 20>, <&dmac0 21>; dma-names ="tx", "rx"; status = "disabled"; }; sysmgr: sysmgr@10d12000 { compatible = "altr,sys-mgr-s10","altr,sys-mgr"; reg = <0x10d12000 0x500>; }; timer0: timer0@10c03000 { compatible = "snps,dw-apb-timer"; interrupts = <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH>; reg = <0x10c03000 0x100>; clocks = <&clkmgr AGILEX5_L4_SP_CLK>; clock-names = "timer"; }; timer1: timer1@10c03100 { compatible = "snps,dw-apb-timer"; interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>; reg = <0x10c03100 0x100>; clocks = <&clkmgr AGILEX5_L4_SP_CLK>; clock-names = "timer"; }; timer2: timer2@10d00000 { compatible = "snps,dw-apb-timer"; interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>; reg = <0x10d00000 0x100>; clocks = <&clkmgr AGILEX5_L4_SP_CLK>; clock-names = "timer"; }; timer3: timer3@10d00100 { compatible = "snps,dw-apb-timer"; interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; reg = <0x10d00100 0x100>; clocks = <&clkmgr AGILEX5_L4_SP_CLK>; clock-names = "timer"; }; uart0: serial@10c02000 { compatible = "snps,dw-apb-uart"; reg = <0x10c02000 0x100>; interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; resets = <&rst UART0_RESET>; status = "disabled"; clocks = <&clkmgr AGILEX5_L4_SP_CLK>; }; uart1: serial@10c02100 { compatible = "snps,dw-apb-uart"; reg = <0x10c02100 0x100>; interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; reg-shift = <2>; reg-io-width = <4>; resets = <&rst UART1_RESET>; status = "disabled"; clocks = <&clkmgr AGILEX5_L4_SP_CLK>; }; usb0: usb@10b00000 { compatible = "snps,dwc2"; reg = <0x10b00000 0x40000>; interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>; phys = <&usbphy0>; phy-names = "usb2-phy"; resets = <&rst USB0_RESET>, <&rst USB0_OCP_RESET>; reset-names = "dwc2", "dwc2-ecc"; clocks = <&clkmgr AGILEX5_USB2OTG_HCLK>; clock-names = "otg"; iommus = <&smmu 6>; status = "disabled"; }; usb31: usb1@11000000 { compatible = "intel,agilex5-dwc3"; reg = <0x11000000 0x100000>; ranges; #address-cells = <1>; #size-cells = <1>; clocks = <&clkmgr AGILEX5_USB31_SUSPEND_CLK>, <&clkmgr AGILEX5_USB31_BUS_CLK_EARLY>; resets = <&rst USB1_RESET>, <&rst USB1_OCP_RESET>; reset-names = "dwc3", "dwc3-ecc"; status = "disabled"; dwc3_0: usb@11000000{ compatible = "snps,dwc3"; reg = <0x11000000 0x100000>; interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>; iommus = <&smmu 7>; phys = <&usbphy0>, <&usbphy0>; phy-names = "usb2-phy", "usb3-phy"; maximum-speed = "super-speed-plus"; snps,dis_u2_sysphy-quirk; snps,dma_set_40_bit_mask_quirk; }; }; eccmgr { compatible = "altr,socfpga-a10-ecc-manager"; altr,sysmgr-syscon = <&sysmgr>; #address-cells = <1>; #size-cells = <1>; interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 95 IRQ_TYPE_EDGE_RISING>, <GIC_SPI 120 IRQ_TYPE_EDGE_RISING>, <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "global_sbe", "io96b0" , "io96b1", "sdm_qspi_sbe", "sdm_qspi_dbe", "sdm_seu"; interrupt-controller; #interrupt-cells = <2>; ranges; ocram-ecc@108cc000 { compatible = "altr,socfpga-a10-ocram-ecc"; reg = <0x108cc000 0x100>; interrupts = <1 IRQ_TYPE_LEVEL_HIGH>; }; usb0-ecc@108c4000 { compatible = "altr,socfpga-usb-ecc"; reg = <0x108c4000 0x100>; altr,ecc-parent = <&usb0>; interrupts = <2 IRQ_TYPE_LEVEL_HIGH>; }; tsn0-rx-ecc@108c0000 { compatible = "altr,socfpga-eth-mac-ecc"; reg = <0x108c0000 0x100>; altr,ecc-parent = <&gmac0>; interrupts = <4 IRQ_TYPE_LEVEL_HIGH>; }; tsn0-tx-ecc@108c0400 { compatible = "altr,socfpga-eth-mac-ecc"; reg = <0x108c0400 0x100>; altr,ecc-parent = <&gmac0>; interrupts = <5 IRQ_TYPE_LEVEL_HIGH>; }; tsn1-rx-ecc@108c0800 { compatible = "altr,socfpga-eth-mac-ecc"; reg = <0x108c0800 0x100>; altr,ecc-parent = <&gmac1>; interrupts = <6 IRQ_TYPE_LEVEL_HIGH>; }; tsn1-tx-ecc@108c0C00 { compatible = "altr,socfpga-eth-mac-ecc"; reg = <0x108c0C00 0x100>; altr,ecc-parent = <&gmac1>; interrupts = <7 IRQ_TYPE_LEVEL_HIGH>; }; tsn2-rx-ecc@108c1000 { compatible = "altr,socfpga-eth-mac-ecc"; reg = <0x108c1000 0x100>; altr,ecc-parent = <&gmac2>; interrupts = <8 IRQ_TYPE_LEVEL_HIGH>; }; tsn2-tx-ecc@108c1400 { compatible = "altr,socfpga-eth-mac-ecc"; reg = <0x108c1400 0x100>; altr,ecc-parent = <&gmac2>; interrupts = <9 IRQ_TYPE_LEVEL_HIGH>; }; usb31-ram0-ecc@108c4C00 { compatible = "altr,socfpga-usb-ecc"; reg = <0x108c4C00 0x100>; altr,ecc-parent = <&usb31>; interrupts = <3 IRQ_TYPE_LEVEL_HIGH>; }; usb31-ram1-ecc@108c4800 { compatible = "altr,socfpga-usb-ecc"; reg = <0x108c4800 0x100>; altr,ecc-parent = <&usb31>; interrupts = <11 IRQ_TYPE_LEVEL_HIGH>; }; usb31-ram2-ecc@108c4400 { compatible = "altr,socfpga-usb-ecc"; reg = <0x108c4400 0x100>; altr,ecc-parent = <&usb31>; interrupts = <12 IRQ_TYPE_LEVEL_HIGH>; }; io96b0-ecc { compatible = "altr,socfpga-io96b-ecc"; reg = <0x18400000 0x1000>; interrupts = <95 IRQ_TYPE_EDGE_RISING>; status = "disabled"; }; io96b1-ecc { compatible = "altr,socfpga-io96b-ecc"; reg = <0x18800000 0x1000>; interrupts = <120 IRQ_TYPE_EDGE_RISING>; status = "disabled"; }; sdm-qspi-ecc@10a22000 { compatible = "altr,socfpga-sdm-qspi-ecc"; reg = <0x10a22000 0x100>; interrupts = <8 IRQ_TYPE_LEVEL_HIGH>; }; cram-seu@0 { compatible = "altr,socfpga-cram-seu"; reg = <0x0 0x0>; }; }; watchdog0: watchdog@10d00200 { compatible = "snps,dw-wdt"; reg = <0x10d00200 0x100>; interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>; resets = <&rst WATCHDOG0_RESET>; clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; status = "disabled"; }; watchdog1: watchdog@10d00300 { compatible = "snps,dw-wdt"; reg = <0x10d00300 0x100>; interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; resets = <&rst WATCHDOG1_RESET>; clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; status = "disabled"; }; watchdog2: watchdog@10d00400 { compatible = "snps,dw-wdt"; reg = <0x10d00400 0x100>; interrupts = <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>; resets = <&rst WATCHDOG2_RESET>; clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; status = "disabled"; }; watchdog3: watchdog@10d00500 { compatible = "snps,dw-wdt"; reg = <0x10d00500 0x100>; interrupts = <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>; resets = <&rst WATCHDOG3_RESET>; clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; status = "disabled"; }; watchdog4: watchdog@10d00600 { compatible = "snps,dw-wdt"; reg = <0x10d00600 0x100>; interrupts = <GIC_SPI 175 IRQ_TYPE_LEVEL_HIGH>; resets = <&rst WATCHDOG4_RESET>; clocks = <&clkmgr AGILEX5_L4_SYS_FREE_CLK>; status = "disabled"; }; qspi: spi@108d2000 { compatible = "intel,socfpga-qspi", "cdns,qspi-nor"; #address-cells = <1>; #size-cells = <0>; reg = <0x108d2000 0x100>, <0x10900000 0x100000>; interrupts = <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; cdns,fifo-depth = <128>; cdns,fifo-width = <4>; cdns,trigger-address = <0x00000000>; clocks = <&qspi_clk>; status = "disabled"; }; firmware { svc { compatible = "intel,agilex5-svc"; method = "smc"; memory-region = <&service_reserved>; iommus = <&smmu 10>; altr,smmu_enable_quirk; fpga_mgr: fpga-mgr { compatible = "intel,agilex5-soc-fpga-mgr"; }; fcs: fcs { compatible = "intel,agilex-soc-fcs"; platform = "agilex"; }; temp_volt: hwmon { compatible = "intel,soc64-hwmon"; }; }; }; }; };
Many thanks,
K
