HPS's avatar
HPS
1 year ago
Agilex - i series debugging issue
Hi Intel,
I am currently using the Intel Agilex 7 FPGA I-Series Transceiver-SoC Development Kit with the device number AGIB027R31B1E1V (DK-SI-AGI027FA) for initializing Emmc and Ethernet for data transferring to emmc storage through TFTP
We have used SPL part in U-boot source code for initializing the pheriperals,but while debugging the code it stopped in EL2h mode and it shows error as below
WARNING(CMD452-COR167):
! Breakpoint 1 has benn pended
! No complilation unit matching”/home/anbu/Agilex-I-series_boot/u-boot-socfpga/arch/arm/mach-socfpga/spl_agilex.c” was found
WARNING(CMD315):Target is not running
Thanks & regards
Anbu
  • Jeet14's avatar
    Jeet14
    Can you add these below in the Execute Debugger command in the Arm DS debug as config tab
    interrupt
    restore "u-boot-spl-dtb.bin" binary 0xFFE00000
    loadfile "u-boot-spl"
    core 1
    set $PC = $ENTRYPOINT
    core 2
    core 3
    core 0
    thbreak board_boot_order
    continue
    wait
    set spl_boot_list[0]=0
    set $PC=$LR
    restore "u-boot.itb" binary 0x2000000
    continue
    Tiwari
  • Jeet14's avatar
    Jeet14
    Please let me know if you have any question on this?
    Tiwari
    • HPS's avatar
      HPS
      Still faceing the same issue.
  • Jeet14's avatar
    Jeet14
    Hi Anbu,
    Can you please share the snapshot of the debug configurations used in ARM DS?
    Tiwari
    • HPS's avatar
      HPS
      Please find the attached image for your reference and also i have mentioned the execute debugger commands below.
      interrupt
      restore "/home/anbu/Agilex-I-series_boot/u-boot-socfpga/spl/u-boot-spl-dtb.bin" binary 0xFFE00000
      loadfile "/home/anbu/Agilex-I-series_boot/u-boot-socfpga/spl/u-boot-spl"
      core 1
      core 2
      core 3
      core 0
      continue
      wait
      set $PC=$LR
      restore "/home/anbu/Agilex-I-series_boot/u-boot-socfpga/u-boot.itb" binary 0x2000000
      continue
