10 years agoWrong logic synthesis when call function named <package_name>.<function_name>
I am in trouble in VHDL analyze & synthesis. I use "Quartus Prime Verion 15.1.0 Build 185 10/21/2015 SJ Lite Edition". It defines the no argument function in the package. sample.vhd ...
10 years ago --- Quote Start --- ???? http://www.alteraforum.com/forum/showthread.php?t=51340 ok. Did you pay attention on the word "all" in "use" clause? by the way, why multiple call to "use" and "library" if VHDL able only one "use" clause per entity. library ieee; use ieee.std_logic_1164.all, ieee.numeric_std.all, work.sample.all;
--- Quote End --- I think that I am easy to understand that do not use "all" in "use" clause. for example.
package A is
subtype Code_Type is std_loigc_vector(3 downto 0);
function New_Code return Code_Type;
end A;
package B is
subtype Code_Type is unsinged(3 downto 0);
end B;
use work.A;
use work.B;
signal code_a : A.Code_Type := A.New_Code;
signal code_b : B.Code_Type := B.New_Code;
The purpose of this thread is because I wanted to share information, not knowing the solution. Though VHDL has such a description method, it presents a question in what only a tool of Altera does not accept. Thank you for a reply.
