Oliver_I_Sedlacek
Contributor
1 year agoWindows sees USB blaster but Quartus doesn't, why?
After using my USB blaster successfully with SignalTap to configure and debug my Cyclone4 part, SignalTap and the programming software aren't reliably seeing the USB blaster (by which I mean only 5% ...
NurAiman_M_Intel
1 year agoHi,
From the observation made so far, the root cause is high probably due to software issue on that particular PC as it is working fine on the other PC. As Fvm said earlier, the only way to move forward is to uninstall first and re-install back the related software.
Aiman
