16 years ago
Windows 7 NIOS Cmd Prompt Network Drive ls error
I having an error where I can't list a network drives directory's contents from the NIOS II Command Prompt, although I can cd into the directories. Here's the ls output:
[NiosII EDS]$ ls -al
ls: reading directory .: Function not implemented
total 0
drwxr-xr-x 1 StefanLevie mkpasswd 0 Jan 25 10:13 ./
drwxr-xr-x 1 StefanLevie mkpasswd 0 Jan 11 18:16 ../
Windows7 x64, Quartus 9.1.
And yes I know Altera is not fully supported on 7, but I had to get away from Win2000 to run 9.x.
Thoughts? Solutions?
    I just tried out the NIOS II command prompt on my Windows 7 x64 system with a network drive.
    If I run the command prompt as myself (not as administrator), I can access network drives fine. If I run the command prompt as administrator, I can no longer access the network drive. However, I find that many of the NIOS tools do not actually work correctly unless I run the command prompt as administrator.
    you might look into the cygwin mailinglists to see if other users are experiencing similar issues with Windows 7 (listing network drives) and if there is a work around. search the web for windows 7 cygwin.
