16 years agoI just tried out the NIOS II command prompt on my Windows 7 x64 system with a network drive.
If I run the command prompt as myself (not as administrator), I can access network drives fine. If I run the command prompt as administrator, I can no longer access the network drive. However, I find that many of the NIOS tools do not actually work correctly unless I run the command prompt as administrator.
