Will not read EPM7128S
Examine/read was deprecated by Altera around the Quartus 11 to 13 timeframe. Program/verify/blank check work. Examine does not.
They removed the feature by QuartusII 13.0sp1. No reason was given, it was just removed. So you cannot read the device program.
Note this was specific to the MAX EPM3k and EPM7k series. Other parts like CycloneII etc can be both written and read back.
You can program and then verify. If you can do that you have by default the current program file of the device.
But if you have some random MAX device and you want to examine/read the device program (eg, to copy to another device) you are out of luck.
I have an earlier installs of QuartusII 6.1/9.1sp2/13.0sp1 and it does allow read/examine of the EPM3xxxS and EPM7xxxS series parts and saving the contents to a file, using a USB Blaster.
A third party programmer would also likely be able to read the device program. I can do this on my EEtools TopMaxII.
- Maxcat8002 years ago
I installed Quartus II 9.1sp2 and still no luck with reading the device. I can write and verify the file and the security bit is off.
- _AK6DN_2 years ago
Looks like you are right.I had based my earlier answer on my tests using an EPM3064A and EPM7064S devices using QuartusII Web 9.0sp2.I have development boards with those devices and QuartusII Web 13.0sp1 cannot examine them, but QuartusII Web 9.0sp2 can.For each of those devices I could read/examine the device program to a file, and then use that file to verify the program.So I (wrongly, it appears) extrapolated the functionality to the EPM7128S device.I pulled out my EPM7128S development board, and lo and behold examine is not enabled (no checkbox capability) ineither of QuartusII Web 13.0sp1 (expected), but NOT present in either QuartusII Web 9.0sp2 or QuartusII Web 6.1. Theexamine (and erase) check boxes are disabled for the EPM7128S across the board in all tested versions.So it appears that the correct answer is there is partial capability for examine of EPM3xxxA and EPM7xxxS devices in earlierQuartus versions. I don't have access to any Quartus versions prior to 6.1 nor do I have any MaxPlusII versions.So the exact Quartus version that stopped being able to examine an EPM7128S will remain a mystery for now.Ok lets start all over again and redo all the tests I can do from scratch instead of relying on partial memory.
I have QuartusII 13.0sp1, 9.1sp2, and 6.1 available.
I have boards with an EPM3064A, an EPM7064S, and an EPM7128S available.
Trying all the combinations of boards and program/verify/examine functionality I get this matrix.
3064A 7064S 7128S QuartusII 6.1 program/verify/examine/erase program/verify program/verify QuartusII 9.1sp2 program/verify/examine/erase program/verify program/verify QuartusII 13.0sp1 program/verify/examine/erase program/verify program/verify
So as can be seen ONLY the EPM3064A supports the examine feature in QuartusII versions I tested.
Neither of the EPM7064S nor EPM7128S support the examine feature in any of those versions.I can't say about earlier Quartus versions as I don't have those anymore (6.1 is from 2006). At some point I suspect
Quartus supported the examine function for the EPM7nnnS parts but I can't say when based on the tools I have available.- Maxcat8002 years ago
I tried version 2.1, 2.2, 4.1, 4.2, 5.0 and 5.1. Examine/read function disabled on all of them for EPM7nnnS parts. I don't know if this function ever was enabled or the versions, I found online have been updated to not allow this function.
