15 years ago
why warning "Missing drive strength" ?
Hello all,
I am a beginner of Altera FPGA. Today I wrote a simple project with Quartus II 10.0. I set the device as EP3C25, then I wrote a simple VHDL, assigned the location and IO standard. When I compile this project, I always got a warning:"Some pins have incomplete I/O assignments. Refer to the I/O Assignment Warnings report for details". I check the assignment waring report, and all out pins are identified as "missing drive strength".
I changed the device to EP1C12, reassign the location, the warning is eliminated. I did some tests, and found that if I use Cyclone III device, this warning will come out. Could anybody tell me why?
    Drive strenght is the maximum current that the pin can drive.
    In modern FPGA this is programmbale.
    If you don't set the value you get a warning saying that a default value (probably the highest current) has been set.
    This is not a problem unless you don't have signal integrity problems
    in the integration of your FPGA on the final board.
    I think that when you don't get the warning is because the value is not programmable
    --- Quote Start ---
    Thank you. Could you tell how to program the drive strength?
    --- Quote End ---
    In the pin planner in the pin list there's a column called current strength.
    If it doesn't show up there, right-click your mouse in the pin list and select customize columns.... You can add the currenth strenght column and select the desired drive strength.
    good luck, Ton
    The warning is eliminated when I did what you told me to do.Thank you.
