15 years ago --- Quote Start --- Thank you. Could you tell how to program the drive strength? --- Quote End --- In the pin planner in the pin list there's a column called current strength. If it doesn't show up there, right-click your mouse in the pin list and select customize columns.... You can add the currenth strenght column and select the desired drive strength. good luck, Ton
