Altera_ForumHonored Contributor15 years agowhy warning "Missing drive strength" ? Hello all, I am a beginner of Altera FPGA. Today I wrote a simple project with Quartus II 10.0. I set the device as EP3C25, then I wrote a simple VHDL, assigned the location and IO standard. Wh...Show More
Altera_ForumHonored Contributor15 years agoThank you. Could you tell how to program the drive strength?
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
