Xuzeng_
1 year agowhy tx_pll_pocked and rx_cdr_pocked is always Not locked.
There is my some code about the clk,and the signal "CLK_QSFP_0_P" is connected to the REFCLK pin. When i use the tool "system console"to test the prbs,it's always not work.
Ash_R_Altera
1 year agoHi,
Thanks for the update. From the screen shot, I cannot figure out whether any internal or external loopback is enabled or not. That is a way to ensure whatever you are transmitting is reaching the Rx pins.
As I mentioned earlier, basically you need to make sure that the data is being received at the right rate on the receiver pin.
