MRigh4
6 years agoWhy Quartus Prime crashes when I try to early floorplan a design using Design Partitions and logiclock regions?
When I launch the Analysis and Synthesis process in a design with a certain number of partitions and relevant logiclock regions, Quartus Prime shows an error message with the attached problem descrip...
KhaiChein_Y_Intel
6 years agoHi,
Sure. You may open a new forum thread if you can replicate the problem with a simpler case. Thank you so much for the effort as this helps to improve our software quality.
KhaiY
