MRigh4
6 years agoWhy Quartus Prime crashes when I try to early floorplan a design using Design Partitions and logiclock regions?
When I launch the Analysis and Synthesis process in a design with a certain number of partitions and relevant logiclock regions, Quartus Prime shows an error message with the attached problem descrip...
KhaiChein_Y_Intel
6 years agoHi,
It is glad that you found a root cause. You may disabling this feature in the QSF as a temporary workaround. I understand that providing the full design is not possible. Is it possible to provide a simple test case for error replication? If I can reproduce the error, I will send it to engineering team for a fix in the future release.
KhaiY
