MRigh4
6 years agoWhy Quartus Prime crashes when I try to early floorplan a design using Design Partitions and logiclock regions?
When I launch the Analysis and Synthesis process in a design with a certain number of partitions and relevant logiclock regions, Quartus Prime shows an error message with the attached problem descrip...
MRigh4
6 years agoHello KhaiY_Intel,
unfortunately I can't share the design file due to company restrictions, but it seems that the problem is in the parallel compilation feature, since disabling it in the QSF file ( setting set_global_assignment -name NUM_PARALLEL_PROCESSORS 1) , the analysis and synthesis process runs successfully.
