Why is the build time of a simple project in Quartus Prime Pro so long?
Hi Jacek,
Generally, there many ways you can change manually in order to speed the compilation process. Refer to link below for details. Document below shows configurations and steps depending on your need. Easily way for setting if you dont want to manually change it is to enable Aggressive Compile Time (Reduces the compile time required to implement the design with reduced effort and fewer performance optimizations). Go to Assignment --> Setting --> Compiler setting --> Optimization mode --> select (desired optimization mode,refer to link below for type of opt mode). Hopefully it helps.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-compiler.pdf
p60- Optimization mode
p84- Reducing compilation time
