JPlus's avatar
JPlus
7 years ago
Why does Quartus put a LE buffer cell in series with the output of an LE cell (adder cell) and the input to the downstream FF? See highlighted element in schematic. Is there a way to disable this?
  • JPlus's avatar
    JPlus
    I'm looking at the Technology Map Viewer (Post-Fitting) option under Fitter (Place & Route). I found no such option 'Enable Input/Output register assignment' in the Assignment editor (from the long list of items presented). Only 'Fast Ouput register' which tells Quartus (according to my reading) to put the register in an I/O cell. What version of Quartus are you using? I'm using 18.1 Standard edition.
  • JPlus's avatar
    JPlus
    I'm giving up on trying to do this on an Altera part. Two weeks of pain and frustration is all that I can tolerate. I tried every option that made sense. I even tightened the timing constraint to point of failure but still Quartus insisted on keeping the buffers. I don't know how Abe created his version without the buffers, except perhaps you are using something other than Quartus??? To me, this buffer insertion is a total waste of resources. 128 LE are being used to do this (actually many more exist in the design) and for what? Perhaps this is a bug in 18.1? Something is not right! The TDC critically depends on these buffers NOT being there, so this is a failed attempt at building a PUF on Altera FPGAs.
  • Abe's avatar
    Abe
    Have you tried the "Ignore LCELL buffers" constraint in the Assignment editor? This will tell the compiler to ignore LCELLs.
  • KennyT_altera's avatar
    KennyT_altera
    let us know if the "Ignore LCELL buffers" works? If not, can you attached your simplified design.qar files for us to have a look?
