where's the license file?
Or can i simply install the Questa component on what's currently there? I'm presuming newer and older versions do not mesh...
You can't do that. There's compatible issue.
So here is my problem, because we don't have an extension to use ModelSIM floating license until our classes end in the late April, I am being forced to upgrade labs to a newer version of the Quartus prime Standard software.
I installed the Suite on a test computer, and the 23.1 version of Quartus still recognizes the license daemon running on the server. At least at launch, i have not tried to compile or download a project file to a MAX 10 board.
I ran the new License daemons on a test sandbox computer to see what to expect when i do it on the actual license server we have. I noticed on the download page that the new license server for Siemens, requires a change to a license file - changing the name of the daemon from mgcld to saltd, only for the VENDOR statement, not the INCREMENT statements.
So because even with the daemon changes just noted, can I still have a 'merged' license file pointing to 3 license daemons on the server?
Effectively creating a grace period to avoid disruption to courses by combining or including three vendor lines in a new license file ?
Quartus, ModelSIM, and Questa?
Thank You,
