Where are the example files
- 2 years ago
Didn't realize that about the HDL selection. VHDL probably coming in a future version.
The whole point of an IP is that it isolates you from these details. All you need to do is use the programming model for the IP (either at the hardware level with register access or at the software level with macros created using software tools) to read and write the memory. And again, since most of the interface in newer devices is hardened, the only HDL code you will see is the implementation of the Avalon or AXI connection to the hard IP.
As far as a processor is concerned, if you are talking about the HPS in an SoC device, rocketboards.org is the place to go for examples.
If you are looking at learning the details of signaling between the FPGA and the external memory, download a spec sheet from Micron or any memory manufacturer. Very detailed explanations on how everything works.
I believe so. I am using the example design tab in the IP to generate the Verilog files (attached image). It created a new folder called the example design. The other attached image are all the files and folders in the IP folder. Where is the top-level actually at? I see some .v files, but none of them seem like code that will program the memory, or even connect to other files.
On a semi-related note, I can only get Verilog files, is VHDL not supported for EMIF?
Thank you,
Drew
