what problem with SDK for OPenCL v17.1
Hi all!
I'm trying run opencl example hello_world on quartus v17.1. the compiler guider document wrote that compiler time may some hours. but i run two days, still don't have result. what is the matter with my object? Thanks for your help. https://alteraforum.com/forum/attachment.php?attachmentid=15384&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=15384&stc=17 Replies
Please post the specs of your compilation machine (CPU model, memory size) and attach the "quartus_sh_compile.log" file.
--- Quote Start --- Please post the specs of your compilation machine (CPU model, memory size) and attach the "quartus_sh_compile.log" file. --- Quote End --- CPU intel Core I5-6500, 16gb of Ram, windows 7 64bit i dont understand what is the ""quartus_sh_compile.log" file? - Altera_Forum
When you are compiling the kernel, a folder will be created on your disk with the same name as the kernel. Look inside that folder for the file that I mentioned. It includes the compilation log. Also please mention your FPGA board name.
--- Quote Start --- When you are compiling the kernel, a folder will be created on your disk with the same name as the kernel. Look inside that folder for the file that I mentioned. It includes the compilation log. Also please mention your FPGA board name. --- Quote End --- it is true that the system generate a new folder ,but i still dont find the quartus_sh_compile file that you mentioned. I just run the hello_world example, so dont require connect to any FPGA Board - Altera_Forum
This has nothing to do with whether you have an FPGA board or not. If you don't have the quartus_sh_compile file, it means the placement and routing process has not even started.
--- Quote Start --- This has nothing to do with whether you have an FPGA board or not. If you don't have the quartus_sh_compile file, it means the placement and routing process has not even started. --- Quote End --- So if i install a board, that proplem is solved or not? And because size of RAM(16Gb) of my PC, so the compile time will take along time? - Altera_Forum
This problem is not related to whether you have a board installed or not. 16 GB is enough for targeting Cyclone devices; for bigger devices, you need much more memory. Check the following page for Altera's memory size recommendations:
http://dl.altera.com/requirements/18.0/
