8 years agowhat problem with SDK for OPenCL v17.1
Hi all! I'm trying run opencl example hello_world on quartus v17.1. the compiler guider document wrote that compiler time may some hours. but i run two days, still don't have result. what is...
8 years ago --- Quote Start --- When you are compiling the kernel, a folder will be created on your disk with the same name as the kernel. Look inside that folder for the file that I mentioned. It includes the compilation log. Also please mention your FPGA board name. --- Quote End --- it is true that the system generate a new folder ,but i still dont find the quartus_sh_compile file that you mentioned. I just run the hello_world example, so dont require connect to any FPGA Board
