8 years agowhat problem with SDK for OPenCL v17.1
Hi all! I'm trying run opencl example hello_world on quartus v17.1. the compiler guider document wrote that compiler time may some hours. but i run two days, still don't have result. what is...
8 years ago --- Quote Start --- This has nothing to do with whether you have an FPGA board or not. If you don't have the quartus_sh_compile file, it means the placement and routing process has not even started. --- Quote End --- So if i install a board, that proplem is solved or not? And because size of RAM(16Gb) of my PC, so the compile time will take along time?
