What kind of IP Catalog do I need change?
- 6 years ago
I'm not sure what you mean about changing the IP Catalog.
As the upgrade dialog indicates, you need to upgrade the IP listed. Try the automatic update (the button at the bottom of that dialog) first. Chances are you won't be able to upgrade the PLL IPs because the PLLs are very different between those devices (though your message seems to indicate that the PLL did update successfully). For any IP that doesn't automatically upgrade, you'll have to delete the IP and re-add it to the design from the Quartus IP Catalog.
#iwork4intel
#iwork4intel
