KAthu
6 years agoWhat is the most efficient way to configure different weak pull ups for the same design to create different bitstreams?
Hi, I have a verilog design. I am trying create several different bitstreams from it, say 3. The only difference in those bit streams will be, which pins have weak pull-ups. I know that one way to...
YuanLi_S_Intel
6 years agoHi Kasun,
No, you will need to reprogram in order to change the setting of weak pull ups on diff pins.
Thank You.
