ZhiqiangLiang
1 year agowhat is Configuration Device in Convert Programming Files?
Hi, I am using Quartus 18.1 to program Cyclone 10 LP 10CL120. The flash that connect FPGA is M25P64(https://www.datasheetq.com/en/preview/M25P64-ST-Microelectronics) the questions are: 1) File --...
WZ2
1 year agoI'm not sure which manufacturer the M25P64 flash you mentioned belongs to. Altera has recommended and verified flash devices from specific manufacturers—please refer to Table 4 in the linked document for details.
If your flash device is not listed there, you first need to confirm whether it can be used as a boot device for Cyclone devices. You can do this by checking parameters like dummy cycles, addressing, etc., as outlined in Table 4 for verified devices.
If you confirm that your flash is compatible, you can generate a new template in the Convert Programming Files tool by selecting "New Device".
