Ways to improve timing on Top module?
Average interconnect usage (total/H/V) 50.7% / 48.7% / 57.0%
Peak interconnect usage (total/H/V) 80.4% / 81.7% / 86.1%
Since average interconnect is less it should not cause any problems in routing right ?
But 8 out of 10 times fitter terminates because of routing congestion.
Is there a way to find which module has high interconnect usage ? So that I can change the coding style and improve timing .
Hi Yogesh,
Yes. There is a way to check which module uses most of the routing resources.
KhaiY
- Yogesh6 years ago
Hi Khai,
I think the screenshot you shared is for quartus pro edition. I am using intel quartus standard edition 18.1
I find only routing usage summary under logic and routing section ,which only talks about resources like Block interconnects
C12 interconnects
C2 interconnects
C4 interconnectsand not about module level usage . Is there someother option to check the same w.r.t each module of my project?
thankyou
regards,
Yogesh
- KhaiChein_Y_Intel6 years ago
Hi Yogesh,
The report in the Pro edition is different from the Standard edition. In this case, you have to check the routing utilization in the Chip Planner.
KhaiY
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
KhaiY
