--- Quote Start --- When compiling my design i get the following warings. Warning: Timing-driven synthesis is skipped because there are multiple hierarchies in the design Warning: Timing-driven synthesis is skipped because it could not initialize the timing netlist I think this is the reason I am getting some timing issues with my design. What does it mean and how do I fix it. All help would be appreciated. --- Quote End --- Hi, looks strange. Are you using design partitions ? Is the SDC file in the project included? Which device are you using ? Kind regards GPK - Altera_Forum
Thanks for you reply.
I am using a stratixIII device. I dont think the project has any design partitions but it has 4 SDC files, to cover different parts of the design. - Altera_Forum
--- Quote Start --- Thanks for you reply. I am using a stratixIII device. I dont think the project has any design partitions but it has 4 SDC files, to cover different parts of the design. --- Quote End --- Hi, I forgot there is a similar thread in the forum : http://www.alteraforum.com/forum/showthread.php?t=6117 DrJohn issued a service request and got the answer that the problem could be caused by failing constraints in the SDC file. Have a look to the thread, maybe it helps. Otherwise I would recommend to issue a service request again. Kind regards GPK
