12 years ago
Warning: Output pins are stuck at VCC or GND
I am getting the following warning which is giving me an incorrect output.
I am just a beginner at VHDL, request help to rectify the problem.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity norgate is
port(
a : in STD_LOGIC;
b : in STD_LOGIC;
c : out STD_LOGIC
end;
architecture Behave of norgate is
begin
c <= a NOR b ;
end ;
library IEEE;
entity andgate is
port(
x,y,z : in STD_LOGIC;
f : out STD_LOGIC
end;
architecture Behave of andgate is
begin
f <= x AND y AND z ;
end ;
library IEEE;
entity flipflop is
port (
j,k,clock : in STD_LOGIC;
q , qn : buffer STD_LOGIC );
end flipflop;
architecture structure of flipflop is
component norgate is
port(
a : in STD_LOGIC;
b : in STD_LOGIC;
c : out STD_LOGIC);
end component;
component andgate is
port(
x : in STD_LOGIC;
y,z : in STD_LOGIC;
f : out STD_LOGIC);
end component;
signal temp1,temp2: std_logic;
begin
and1: andgate PORT MAP ( j,clock , qn , temp1 );
and2: andgate PORT MAP ( k,clock , q , temp2 );
nor1: norgate PORT MAP ( temp1 , qn , q );
nor2: norgate PORT MAP ( temp2 , q , qn );
end structure;
1 Reply
    Due to wrong circuit, output doesn't depend on inputs and logic completely removed in design optimization. Flip q and qn connection to AND gates.
    The circuit would be correctly named JK latch rather than JK flip-flop because it's level sensitive.
