17 years ago
Warning: No Clocks Defined in Design
Everytime I compile my design in the Quartus II software (the web edition), I get a warning that states "No clocks defined in design" even though in my .bdf file I have an altpll block with the input assigned to the pin associated with with the System Clock. What am I doing wrong?
Thanks!
    I am facing similar problems.
    I am trying to use the clocks provided on DE1 board from TerAsic (24MHz, 27MHz & 50MHz).
    But My code doesn't work.
    This is my code:
    module LedBlink(CLOCK_24, LEDR);
    input[1:0] CLOCK_24;
    output [7:0] LEDR;
    wire ovf;
    reg out;
    reg en, clk, clr;
    reg[31:0] maxClks;
    reg[7:0] div;
    initial
    begin
    clk = 0;
    div = 0;
    out = 0;
    maxClks = 1000000;
    # 10 en=1;
    # 10 clr=1;
    # 20 clr = 0;
    end
    always @(posedge CLOCK_24[0])
    begin
    div = div + 1;
    if(div == 24)
    begin
    clk = ~clk;
    div = 0;
    end
    end
    always @(posedge ovf)
    begin
    out = ~out;
    end
    assign LEDR[0] = out;
    DelCtr del (ovf, en, clk, clr, maxClks);
    endmodule
    I had made use of the CLOCK_24 pin as a clock by using always construct.
    But still I get the warning in quartus "No Clock Source Defined in Design".
    Pls Help
