17 years agoWarning: No Clocks Defined in Design
Everytime I compile my design in the Quartus II software (the web edition), I get a warning that states "No clocks defined in design" even though in my .bdf file I have an altpll block with the input...
11 years agoI am facing similar problems.
I am trying to use the clocks provided on DE1 board from TerAsic (24MHz, 27MHz & 50MHz). But My code doesn't work. This is my code: module LedBlink(CLOCK_24, LEDR); input[1:0] CLOCK_24; output [7:0] LEDR; wire ovf; reg out; reg en, clk, clr; reg[31:0] maxClks; reg[7:0] div; initial begin clk = 0; div = 0; out = 0; maxClks = 1000000; # 10 en=1; # 10 clr=1; # 20 clr = 0; end always @(posedge CLOCK_24[0]) begin div = div + 1; if(div == 24) begin clk = ~clk; div = 0; end end always @(posedge ovf) begin out = ~out; end assign LEDR[0] = out; DelCtr del (ovf, en, clk, clr, maxClks); endmodule I had made use of the CLOCK_24 pin as a clock by using always construct. But still I get the warning in quartus "No Clock Source Defined in Design". Pls Help
