SHard2
6 years agoWarning: field in quartus report that was not expected
Hi I am using Quartus 19.1.0 (patch 0.02std) and DSP Builder with Matlab R2013a. Executing 'Verify Design' in simulink with the 'Run Quartus Prime Software' option ticked gives the following error ...
CheepinC_altera
6 years agoHi,
For your information, I notice that the demo_nco is an example in the DSP Builder. I have tested running with MATLAB R2015a + Q17.0Std using the built in demo_nco. Note that these are the software version that I have in my local PC. There is no issue when I run the DSP Builder -> Verify Design -> Run Verification. The design can pass Simulation, Quartus and Timing tests. Based on the observation to-date, I believe the issue is specific to Q19.1Std or compatibility between Q19.1Std and MATLAB R2013a. I would recommend you to proceed with either of the two workarounds mentioned in my previous post to avoid gating your progress. Sorry for the inconvenience.
Chee Pin
