Warning: field in quartus report that was not expected
Hi again
I have just noticed that the link in your email opens a different support case than the one I have showing under ‘My Intel->MySupport’
The original case is request number 04558711 and has some of my replies to you listed.
The link you sent to me opens a different case with none of my replies visible?
Your link does not seem to have a case request number that I can see??
***** Additional previous replies *****
Hi
Looking a bit deeper there seems to be an extra field inserted in the auto generated 'demo_nco_NCOSubsystem.tcl' file.
Line 91 sets the field names as...
"Logic,ALM_Logic_Regs,ALM_Logic,ALM_Regs,ALM_Mem,Comb_Aluts,Comb_ALUT_Logic,Comb_ALUT_Route,Mem_ALUT,Regs,Regs_1,Regs_2,ALM,DSP,FP_DSP,Mem_Bits,MLAB_Bits,M20K,IO,FMax,Slack,Required"
The field values themselves are added one-by-one, but an extra field entry is added on line 138...
"print_csv $fmax"
This field has no name and therefore causes the error reported in the Matlab command window.
I am unable to simply comment this line out as the file is regenerated each time the verification test is run.
If you can offer any advice it would be gratefully received.
We are seeing exactly the same error in our actual development models, so it is not limited to the examples.
Best Regards
Simon
