Warning: field in quartus report that was not expected
Good morning again,
I have replied immediatly to all of your emails. I do not understand why none are making it through your system to you?
I have also replied both by email and via the forum.
This is an urgent problem for us, and we urgently need advice.
I will send this once again through both the portal and by replying to the email.
Your questions regarding your proposed work arounds are included below from my original reply.
Simon
**** Previous emails are below ****
Good morning,
I did reply to your first email, did you not receive it? I have included it at the end of my reply.
I have attached a zip file, I hope it makes it through your firewall?
Best regards
Simon
<snip>
Good morning and thank you for getting back to me.
(Q 1) Would you mind to try compile the generated Quartus project, in standalone Quartus.
The design will compile correctly and pass timing if I select the following from within the Simulink menu.
DSP Builder -> Run Quartus Prime Software
However if I select the following from within the Simulink menu to open the ‘DSP – Verification’ window.
DSP Builder -> Verify Design
The verification fails with the errors in my first email.
(Q 2) It is recommended for your to try using the latest Q19.4Pro + DSP Builder to see if issue still existing? Just to isolate version dependent issue.
Unfortunately I cannot upgrade Quartus as I am targeting a Stratix IV device which restricts me to Quartus Standard Edition V19.1, this device family is not supported by Quartus Pro.
The install is on Windows 10 64-bit and I have also installed the required patch.
I am using the DSP Builder Advanced Blockset and, according to the intel document ‘hb_dspb_intro.pdf’, I cannot upgrade MATLAB.
The latest compatible version for Quartus Standard Edition V19.1 is MATLAB R2013a.
I cannot find this error listed on the Intel/Altera website as a problem that has been raised previously.
(On a separate PC I have an old setup of MATLAB R2012a and Quartus V13.0.1 installed on windows 7 64 bit. This error does not occur on this older version.)
If you can offer any advice it would be greatly appreciated.
Best regards
</snip>
