SHard2
6 years agoWarning: field in quartus report that was not expected
Hi I am using Quartus 19.1.0 (patch 0.02std) and DSP Builder with Matlab R2013a. Executing 'Verify Design' in simulink with the 'Run Quartus Prime Software' option ticked gives the following error ...
CheepinC_altera
6 years agoHi Simon,
As I understand it, you seems to observe some issue when trying to call Quartus compilation from DSP Builder with your design.
Would you mind to the following to help narrowing the issue and finding potential workaround:
- Would you mind to try compile the generated Quartus project, in standalone Quartus.
- It is recommended for your to try using the latest Q19.4Pro + DSP Builder to see if issue still existing? Just to isolate version dependent issue.
Chee Pin
