mitsvoid
2 years agoWarning (14320): Synthesized away node - FFT IP core
Dear All, I hope you are doing well. I am currently working on creating a custom IP core to integrate with NIOSII. The custom IP encompasses configurations for both the wm8731 and FFT. I am now in...
- 2 years ago
You can simulate the FFT IP without a license. Follow the steps mentioned 2.5. Simulating Intel® FPGA IP Cores
Thank you,
Kshitij Goel
Kshitij_Intel
2 years agoHi Nikolaos,
For this warning, please check below article, that refers to the LVDS IP, but it might be same workaround for your issue as well.
Warning (14320): Synthesized away node "<node... (intel.com)
Please go through it and try it at your end if you are still not able to resolve the issue, please share the simple design to replicate the same warning at my end will try to resolve.
Thank you,
Kshitij Goel
