Warning (13028): Removed fan-out from the always-disabled I/O buffer....
- 2 years ago
So what is the issue and your goal at this point? You have disabled tri-state buffers that are not being used in the design.
Also, it should be mentioned that there is no tri-state logic internal to the FPGA fabric, only in the I/O cells, so that may be part of the issue here as well. Note "I/O buffer" in the warning.
If you are trying to determine what resources are being used and what has been removed, use the Technology Map Viewer (Post-fitting) to see a schematic of the used device resources post-fit.
As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
